Non Structural Components
I am querying about an interpretation of ASCE 7-2002 as referenced by the NYC code. In 9.6.1 the exceptions indicate components with Ip of 1 are exempt from the provisions of the section for a Category C building. Later it says that one should address these items when failure could affect an essential component - perhaps from another trade. While that makes sense to do, I am curious how the code is really interpreted. Is a non-essential item to be restrained whenever an essential item is below it? The essential component may have been installed long after access to the non-essential component is available. Thanks.
RE: Non Structural Components
In this case the issue is non-essential HVAC ductwork already installed followed later by the electrical contractor locating an essential conduit (not sure what, perhaps exit lighting) to cross below the duct. Access may not permit after the fact conventional restraint of the duct, so it seems the contractor installing the the essential element should take care to protect it from unbraced items above it. In no case are we talking about structural integrity of the building. Does your comment apply in this case? Thanks.
