Modify Numeric Data
Modify Numeric Data
We have a survey drawing with several (hundreds) data elevation points on it. They are all 'truncated'... for example the value 5.82 represents 500 + 5.82 for an elevation equal to 505.82. Is there a means of automatically adding the 500 to the number shown (not a text value of 50)?
For example the reason for not using text, there are also some data points at 12.82 and the elevation would be 512.82 and not 5012.82?
Thanks, Dik
Thanks, Dik
RE: Modify Numeric Data
Dik
Dik
Try the attached.
Remove the ".txt" file suffix so it's a ".lsp" file.
Carl
Mike Halloran
Pembroke Pines, FL, USA
Dik
