Over mold question
Over mold question
Over mold question
Hi everyone,
New here and have a quick question. I'm pretty sure I've seen similar to this before but a co-worker doesn't think it can be done.
I want to make a button with an over molded rubber (butyl or santoprene I'm thinking) ring. It's going to act like a ring on a speaker, with button section essentially being like a speaker cone. My plan was to mold the ring, then insert that in to a mold and mold the plastic button over it. Here's a pic of what I'm thinking. The dark grey is the main body this will all get over molded into. The blue would be the ring, and then the light grey would be the button. Will a setup like this work? Are there other parts out done like this? He's thinking that the rubber ring wouldn't be able to survive the plastic being molded over it. My reasoning for molding the ring first, then inserting it in to the button mold is to alleviate the undercut on the button where the ring sits. If you've seen it before, any chance you can send me a link to where it's been done like this in the past? Right now we've only spent about 1/2 a day on the design, so it's still really rough.
Thanks in advance,
Rich
RE: Over mold question
It's going to be easier to mold the more flexible element last, as there will be less problems with the molding pressure pushing the flexible element around (distorting the part). Having the rubber mold last would mean you would invert the joint design you have now, this would increase the section thickness of the rubber, which is not a bad thing.
