How to taper curved section?
I am a beginner with ProE and have not yet successfully found any guide on how to taper a curved section as shown in the attached sketch. I believe the "extrude" function has an option to flare/taper the geometry, but I have not figured out how to apply that to a curved trajectory. The section is an "open" circle with a "neck" for water to travel between the impeller and casing.
RE: How to taper curved section?
Norbert
www.weight-locker.com
http://www.linkedin.com/profile?viewProfile=&k...
