Problem with NX 8.5
Problem with NX 8.5
Problem with NX 8.5
This is very possibly quite simple but for some reason when i try to delete a couple parts from my assembly "attempt to delete an array master component failed" always comes up. The problem is that there are four parts to this array and each one says the same thing. Am i missing something here?
Any advice will help,
Thanks in advance
A J Memphis
RE: Problem with NX 8.5
1. menu Assemblies->Components->Edit Component Array
2. there, you will find your Array
3. delete this array or suppress it
Now, you will be able to delete a couple of parts, that you are tring to delete.
Thanks SvenBom worked like a dream!!
