Need to Edit Out Colors from pdf Plots & Graphs: Which PhotoShop version will work best?
I am in the middle of long research project requiring that I re-digitize a few (less than 30) old "paper-copy-scanned pdf files, and on-line pdf downloads, and on-line document and powe4rpoint files to "read" their graphs and plots.
I have a adequate software package that can digitize the graphs, providing they are in a bmp, png, or jpg format. Worse case, I can even "screen capture" the image into one of these "photo" versions, and use that.
However, several of the "most interesting" plots have very messy, very-much overlapping, very-many superimposed points. The software experts have given me some tips and methods that should work to do this manually (instead of the more frequent automatic curve following routines) but I will need to "edit" the images so that only the red points are "invisible or turned off: this way, the black lines and dots can be read. Then, I need to re-load the image, but only remove the black lines and dots so the red crosses and diamonds can be digitized. Repeat one more time for the blue crosses.
On occasion, I will also need to edit out (erase) the lines and marks as well, but I image just about such programs have an "eraser" function.
OK. This is a method, but what else are you going to do with papers written in the 1950's and 60's?
Which version of {Photoshop - or something else ?? - will do this type of editing on images?
RE: Need to Edit Out Colors from pdf Plots & Graphs: Which PhotoShop version will work best?
Alternately, you may be able to add a layer, set its color type to "multiply" and then paint it with RGB (0,0,255) (which will get rid of the red marks), leaving blue and...some of the black. You'd have to tinker with this method to get what you want.
Photoshop I believe has a "find and replace color" function as well.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
Do than, then draw points over the points on the graph, then collect the coordinates of those points.
Two files are attached below showing the problem of overlapping data points.
Based on the recommendations above - and, again, thanks to all for the analysis - I used Hypersnap graphic markup and editing software to replace the colors with "white" pixels. What surprised me was finding that the "actual color" I thought I was looking at was not "red" or "blue" or even "black". rather, what looked like "red" was softer mix of the three basic colors mixed together. And, at different places, the three were mixed differently for some reason.
Thus, I could not just replace 255 + 0 + 0 with "white" but rather needed a four-step process:
245 + 10 + 10 -> find and replace,
235 + 20 + 20 -> find and replace
225 + 30 + 30 -> find and replace
215 + 40 + 40 ... The Hypersnap program did have a ""tolerance" band for each operation, and I selected the maximum tolerances possible at each step.
It was more difficult than I'd of liked however.
Notice that the colored red "labels" also got replaced with white pixels along with the unwanted data points, but there were always spare pixels left behind each time, which required simple "erase" secondary processing.
