Surface partitionning
I need to partition surface for FEA in Solidworks
Is it possible to make a partition by:
- surface projection ?
- edge projection or
edge on surface ??
RE: Surface partitionning
Maybe this question is best posed to the Solidworks section?
However, if you are using Creo Simulate then you can do this type of edge/surface/volume subset using the Regions toolset in the Refine Model tab...
