adding custom symbols to NX8
Hi we just recnetly updated to NX 8.0.3.4 and I am looking at taking our NX6 custom symbols and pulling them into NX8. I made a copy and added them to the :\CONFIGURATION\UGSNX8\UGII\SYMBOL folder rebooted and no luck. My enviro file points to this directory. UGII_SYMBOL_LIBRARY_DIR=${UGII_CONFIG_DIR}\UGSNX8\UGII\SYMBOL\ What am I doing wrong?
NX 6.0.5.3 in Windows 7
Mechanical designer
RE: adding custom symbols to NX8
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.2 / TC9.1.2
NX 8.0.3.4 in Windows 7
Mechanical designer
But if I remember correctly you need to create a zipfile first which holds all your symbols.
Mechanical Engineer
NX8.5.2 / TC9.1.2
Mechanical designer
Loosing pattern data is normal when you refile patterns.
If you have refiled them you need to open the patterns one by one, fit the pattern ( this is mandatory otherwise it's not created correctly) , and in save options set "save pattern data" to the correct choice.
Unfortunately refiling sets this option to No (or rather removes any setting which was applied to your patterns).
Then save the pattern.
As refiling patterns is kind of a tedious work it is normally advised to skip patterns when refiling.
The fact that they aren't showing isn't caused by them not being refiled..I would find that very strange if it was the cause...
I would look at your folder structure. is it properly defined in the customer defaults? (gateway - reuse library - general)
Mechanical Engineer
NX8.5.2 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
