B31.3 calculation for unlisted materials
Hey engineers,
My company has only unlisted components for tubing. We follow 304 of B31.3 and because there are too many parts, I asked an engineering office to do the calculations for us to prove that the thickness is over the calculated minimum thickness for tubes.
I think, the calculation 3a under 304.1 is easy to use, but this office used a different calculation. They used t= ch+(P/10* D)/2(SEW+(P/10)*Y)) whereas ch is 12,5% additional thickness.
Is it from an ASME calculating program? Can we really use this calculation ?
Is somebody in this community familiar with these unlisted materials. I searched the internet but nobody seams to use ch.
Greetings Silje
Greetings Silje
RE: B31.3 calculation for unlisted materials
Because they prabably use metric system the pressure is in Bar and the allowable stress in N/mm2 (same as MPa) so they need to devide the pressure by 10 to get N/mm2
But there is still the question about the ch-value. I see, it is the c from calculation 2. It is the sum of mechanical allowances.
An Idea why they used 12.5% and not 0,5 mm at it is described in the explanation for c? With 12,5% the additional thickness for my tube is 0,25mm
To me it seems your mixing things up. Review B31.3 304.1.1 eq (2) and (3a) again.
