switch ratiing
switch ratiing
switch ratiing
I am using a switch which is rated at 10a 250VAC 1/2HP, 15A 125VAC 1/2HP UL reconized, CSA certified.  The switch is used to turn on a DC motor with a 30A breaker in-line.  The circuit is supplied with 24 vdc.
my questions....
What is the Max DC current this switch can take?
How can i take a rating like this and calculate the dc current i can use with this switch?
RE: switch ratiing
It depends on nature of load. Please, provide nameplate data of the motor, i.e.
HP or W, type/model, voltage, current, efficiency and manufacturer.
RE: switch ratiing
the circuit is running a vacuum motor and is power by 24VDC battery source.  the motor is a 24VDC, three stage, single speed, tangental discharge bypass.
i am looking to find a possible second source on these switches, and most of the switch manufactures rate there switche in the same type format....so any sugestion you mave have in helping me in understanding these rating i would appreciate it
RE: switch ratiing
Please, provide the nameplate current and wattage or horsepower. These are essential parameters to size the switch.
