ASTM-AASHTO Test Methods Cross-Reference
I have been unable to locate a listing that cross-references the ASTM designation to the AASHTO designation for equivalent test methods.
Any suggestions?
RE: ASTM-AASHTO Test Methods Cross-Reference
As you have this in the "soil testing" forum, try:
http://www.mdt.mt.gov/publications/docs/brochures/...
Note that there will be slight differences between the two - usually AASHTO states that this test is equivalent to ASTM D-XXXX with the following exceptions . . . (at least in the set that I have from the late 1990s).
It is given in the AASHTO "Standards" and "Test methods" both at the beginning of these books published in the past like 1980s. I have not seen new editions.
