Hole Series w/NX Open
Does anyone have any experience with modifying Hole Series between components in NX/Open. From an assembly, I am trying to determine what the component parts are referenced by the Hole Series.
Thank you,
-Pat
Thank you,
-Pat
RE: Hole Series w/NX Open
I have found this command: GetHoleSeriesStartHoleFeature but can't seem to get it to work...
-Pat
Thank you,
-Pat
Here is some code that may get you started; open an assembly that has at least 1 hole series feature and run the journal. It will list the hole series feature and the components used in that hole series feature.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.Features
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Dim featArray() As Feature = theSession.Parts.Work.Features.GetFeatures()
        For Each myFeature As Feature In featArray
            If myFeature.FeatureType.ToUpper = "HOLE ORCHESTRATION" Then
                lw.WriteLine("feature: " & myFeature.GetFeatureName)
                Dim holeSeries As HolePackage = myFeature
                Dim holeBuilder As HolePackageBuilder
                holeBuilder = workPart.Features.CreateHolePackageBuilder(holeSeries)
                Dim startBodies() As Body
                startBodies = holeBuilder.StartHoleData.BooleanOperation.GetTargetBodies()
                Dim middleBodies() As Body
                middleBodies = holeBuilder.MiddleHoleData.BooleanOperation.GetTargetBodies
                Dim endBodies() As Body
                endBodies = holeBuilder.EndHoleData.BooleanOperation.GetTargetBodies
                lw.WriteLine("start body component: " & startBodies(0).OwningComponent.Name & " (" & startBodies(0).Prototype.OwningPart.FullPath & ")")
                For Each tempBody As Body In middleBodies
                    lw.WriteLine("middle body component: " & tempBody.OwningComponent.Name & " (" & tempBody.Prototype.OwningPart.FullPath & ")")
                Next
                lw.WriteLine("end body component: " & endBodies(0).OwningComponent.Name & " (" & endBodies(0).Prototype.OwningPart.FullPath & ")")
            End If
        Next
        lw.WriteLine("")
        lw.Close()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
www.nxjournaling.com
Thanks Cowski,
I got this working but now another question lets say that the startbody is your work part, you have a linked hole feature in the browser. How can you figure out the parent feature/part would be?
-Pat
Thank you,
-Pat
Try the code below...
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim theUFSession As UFSession = UFSession.GetUFSession
        lw.Open()
            'lw.WriteLine(myFeature.GetFeatureName)
            'lw.WriteLine(myFeature.FeatureType)
            'lw.WriteLine("")
                Next
            End If
            If myFeature.FeatureType.ToUpper = "LINKED HOLE PACKAGE" Then
                lw.WriteLine("linked hole package found")
                Dim sourceTag As Tag
                Dim linkBroken As Boolean = True
                theUFSession.Wave.IsLinkBroken(myFeature.Tag, linkBroken)
                If linkBroken Then
                    lw.WriteLine("link to parent geometry is broken")
                Else
                    theUFSession.Wave.AskLinkSource(myFeature.Tag, True, sourceTag)
                    If sourceTag = Tag.Null Then
                        lw.WriteLine("could not fully load parent file...")
                    Else
                        Dim myTaggedObj As TaggedObject
                        Dim sourceFeature As HolePackage
                        Dim sourceFile As Part
                        myTaggedObj = theSession.GetObjectManager.GetTaggedObject(sourceTag)
                        sourceFeature = myTaggedObj
                        sourceFile = sourceFeature.OwningPart
                        lw.WriteLine("parent file: " & sourceFile.FullPath)
                        lw.WriteLine("parent feature: " & sourceFeature.GetFeatureName)
                    End If
                End If
            End If
        Next
        lw.WriteLine("")
        lw.Close()
    End Sub
    End Function
End Module
how to use this code in ug
