Diesel Cycle temperatures & pressures
Working with IC cycles here-
investigating the ASE of dual combustion cycle here -
when finding the temperatures and pressures, to find v3 you use the following equation v3 = P2V2/T2 = P3V3/T3. Then you rearrange this to find v3, but I cant seem to rearrange this correctly, anybody know what the equation is?
I am also not sure what the equation is to find P4 and T4.
I have found all other pressures and temperatures apart from the 3 mentioned aboove.
The ASE should work out to be around 60%, so if thats what you get you can be pretty sure the maths is correct.
RE: Diesel Cycle temperatures & pressures
Any classical thermodynamics book or even Wikipedia on the net will have the relationships that you need for a diesel cycle.
