Heat transfer simulation. Estimate total heat flux on surface
Using Simulation on ST5 Premium and doing a heat transfer problem I wish to acess the designs of thermal insulation.
I can get a profile of heat flux at outer surface but can't find out how to work out the total heat flux at the surface.
See attached image.
Is this possible?
Many thanks?
See attached image.
Is this possible?
Many thanks?
RE: Heat transfer simulation. Estimate total heat flux on surface
Ken G.
http://grundey.blogspot.com
Have you checked out the Solid Edge Community site?
http://community.plm.automation.siemens.com/t5/Sol...
