Copy Partbody from product Instance
I need to copy a partbody from an instance of a product to another product. How might I go about this?
Copying:"Removal : male"
to
"55227-8#K813 Male Plate.CATPart"
syntax may not be perfect, looking for code on how to access specific instances. copying from the document as a whole seems to give an error.
What do you recommend?
THANK YOU VERY MUCH IN ADVANCE!
Peter
CODE:
for i=1 to cavNumb
cavdesign = "55227 Cavity Design." + i
Set product3 = products2.Item(cavdesign) 'loop this
Set products3 = product3.Products
Set product4 = products3.Item("55227 Male Cavity.1")
'ERROR IS IN HERE I THINK
set product4 = product4.parts
set myPart = product4.part
set DerBODIES = myPart.Bodies
' ^i have no idea how to access an instance of a product
Set theBody = theBodies.Item("Removal : male")
selection1.add theBody
Set partDocument2 = documents1.Item("55227-8#K813 Male Plate.CATPart")
Set part2 = partDocument2.Part
selection2.Add part2
selection2.Paste
next
to
Peter
CODE:
for i=1 to cavNumb
selection2.Paste
next
RE: Copy Partbody from product Instance
As I understood, you have a product with few catparts and you want to copy bodies from a specific catpart to another one (inside same loaded product)?
Then you need to make first active the target part (blue highlight, using Part Workbench) and then use Paste (with or without link ? ).
If I remember correctly there is somehow a similar post here in forum.
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
EX.
552278 Cavity Design(552278 Cavity Design.1)
552278 Cavity Design(552278 Cavity Design.2)
552278 Cavity Design(552278 Cavity Design.3)
Need to access each of ^ these and copy out a partbody they hold WITH link.
Peter
Language="VBSCRIPT"
Sub CATMain()
Set productDocument1 = CATIA.ActiveDocument
Set documents1 = CATIA.Documents
Set partDocument1 = documents1.Item("55227 Male Cavity.CATPart")
'---- Begin resolution script for object : 55227 Cavity Design.1
Set product1 = productDocument1.Product
Set products1 = product1.Products
Set product2 = products1.Item("Cavity Group.3")
Set products2 = product2.Products
Set product3 = products2.Item("55227 Cavity Design.1")
'---- End resolution script
search(product2)
end sub
Sub Search(oProduct)
Dim Prod1
For i = 1 To oProduct.Products.Count
Set Prod1 = oProduct.Products.Item(i)
'Rename here
If Prod1.Products.Count <> 0 Then
copy(prod1)
End If
Next
End Sub
sub copy(oProd)
'msgbox oProd.name
Set bodies1 = oProd.Bodies
Set body1 = bodies1.Item("Removal : male")
body1.copy
'dfffff.PasteLink
End Sub
You are using recording function as I can see, your macro is very posible not to work for other products or parts or if someone is doing a small change in the part which now have (for example) Cavity Group.3
So called "Hard code" is not the best idea (I must admit I'm using also but just for quick-dirty macros as someone said...).
Is dificult to recreate and test your scenario without some sample files (and again, I believe no one is loosing time to recreate a Product structure).
Fernando
In response, this macro is necessary because otherwise I would need to copy and paste manually upwards of 60times (before doing other steps). Please examine this code:
It is working up until the copy paste section:
Language="VBSCRIPT"
Sub CATMain()
search(product2)
end sub
Dim Prod1
'Rename here
copy(prod1)
End If
Next
End Sub
sub copy(oProd)
dim sel
'msgbox oProd.name
'NEED CODE HERE
Set products3 = oProd.Products
Set myObject = products3.Item("55227 Male Cavity.1")
Set HEREISIT= myObject.ReferenceProduct
set prodDoc = HEREISIT.parent
Set thepart1 = prodDoc.Part
Set bodies1 = thepart1.Bodies
'get solids here
Set sel = prodDoc.Selection
sel.add body1
'sel.copy
CATIA.ActiveDocument.Selection.Copy()
dim selection2
Set documents11 = CATIA.Documents
Set partDocument22 = documents11.Item("55227-8#K813 Male Plate.CATPart")
Set part22 = partDocument22.Part
set selection2 = partDocument22.selection
selection2.Add part22
'selection2.PasteLink
'selection2.Paste
'THIS GIVES AN ERROR
CATIA.ActiveDocument.Selection.PasteLink()
'part11.PasteLink
End Sub
I am attaching a sample file of our companies file structure. This document should be used as an example, only to better understand what needs to be accomplished.
The macro should take:
-Cavity Group (Cavity Group.3)
----SAMPLE Cavity Design(55227 Cavity Design.X) <-This product will be cycled in a for loop.
---------55227 Male Cavity (55227 Male Cavity.1)
---------------Removal : male
COPY TO:
-SAMPLE Male Plate(Male1)
At the end, SAMPLE Male Plate Should Contain many "Removal : Male" bodys
Thank you
One solution could be like in code below in CATScript, is done just for one body, you need to adapt the code for the others....or find another solution, for example to copy all bodies in one shot.
CODE --> CATScript
Language="VBSCRIPT" Sub CATMain() Dim productDocument1 As Document Set productDocument1 = CATIA.ActiveDocument Dim selection1 As Selection Set selection1 = productDocument1.Selection selection1.Clear ''''''''''''''get the part from where you copy the body Dim documents1 As Documents Set documents1 = CATIA.Documents Dim partDocument1 As Document Set partDocument1 = documents1.Item("55227 Male Cavity.CATPart") Dim part1 As Part Set part1 = partDocument1.Part Dim bodies1 As Bodies Set bodies1 = part1.Bodies Dim body1 As Body Set body1 = bodies1.Item("Removal : male") selection1.Add body1 selection1.Copy '''' copy Removal : male ''''''''''''''activate the target part Dim selection2 As Selection Set selection2 = productDocument1.Selection selection2.Search "Name='SAMPLE Male Plate',all" ''''''select by searching the name Set partDocument1 = documents1.Item("55227-8#K813 Male Plate.CATPart") Dim editPart Set editPart = partDocument1 CATIA.StartWorkbench("PrtCfg") editPart.Activate()' '''''make the part active (highlight - blue color) selection1.PasteSpecial "CATPrtResult" ' ----- Perform Paste As Result With Link End SubRegards
Fernando
I don't think my main problem is being communicated correctly. I have working copy and paste code, but what I don't understand is how to copy specific items (I.e SAMPLE Cavity Design 55227 Cavity Design.X) and NOT the document itself. My "Search" subroutine loops through each product I need and calls the copy routine with the correct part. Inside sub copy how do I select and copy prod (and NOT partDocument1)?
NOTE: Different names are used in this code (not SAMPLE) but the tree structure is identical.
CODE --> catVBA
Language="VBSCRIPT" Sub CATMain() Set productDocument1 = CATIA.ActiveDocument Set documents1 = CATIA.Documents Set partDocument1 = documents1.Item("55227 Male Cavity.CATPart") '---- Begin resolution script for object : 55227 Cavity Design.1 Set productDocument1 = CATIA.ActiveDocument Set product1 = productDocument1.Product Set products1 = product1.Products Set product2 = products1.Item("Cavity Group.3") Set products2 = product2.Products Set product3 = products2.Item("55227 Cavity Design.1") '---- End resolution script search(product2) end sub '************************************************************************************************* Sub Search(oProduct) 'THIS SUB RETURN EACH PRODUCT Dim Prod1 For i = 1 To oProduct.Products.Count Set Prod1 = oProduct.Products.Item(i) 'Rename here If Prod1.Products.Count <> 0 Then copy(prod1) msgbox prod1.name End If Next End Sub '************************************************************************************************** sub copy(oProd) Dim productDocument1 Set productDocument1 = CATIA.ActiveDocument Dim documents1 Set documents1 = CATIA.Documents Dim partDocument1 Set partDocument1 = documents1.Item("55227 Male Cavity.CATPart") Dim part1 Set part1 = partDocument1.Part Dim bodies1 Set bodies1 = part1.Bodies Dim body1 Set body1 = bodies1.Item("Removal : male") Dim selection1 Set selection1 = productDocument1.Selection selection1.Add body1 selection1.Copy paste end sub '************************************************************************************************* '************************************************************************************************* sub paste Set productDocument1 = CATIA.ActiveDocument Set documents1 = CATIA.Documents Set partDocument1 = documents1.Item("55227 Male Cavity.CATPart") Dim selection2 Set selection2 = productDocument1.Selection 'selection2.Search "Name='SAMPLE Male Plate',all" ''''''select by searching the name selection2.Search "Name='55227-8#K813 Male Plate',all" ''''''select by searching the name Set partDocument1 = documents1.Item("55227-8#K813 Male Plate.CATPart") Dim editPart Set editPart = partDocument1 'CATIA.StartWorkbench("PrtCfg") editPart.Activate() ' selection1.PasteSpecial "CATPrtResult" ' ----- Perform Paste As Result With Link 'CATIA.ActiveDocument.Selection.PasteLink() CATIA.ActiveDocument.Selection.Paste End SubRegards,
Peter
Hope you understood the hierarcy in a Product structure. You can copy what ever you want by making the parts active (blue highlight) and make the target active and paste there (and this can be done under CATProduct or in separate windows...).
Fernando
So within the sub search, activate the specific part before trying to copy from it?
CODE --> catVBA
Sub Search(oProduct) 'THIS SUB RETURN EACH PRODUCT Dim Prod1 For i = 1 To oProduct.Products.Count Set Prod1 = oProduct.Products.Item(i) 'Rename here If Prod1.Products.Count <> 0 Then 'ACTIVATE CODE HERE <------------------------------------------------------------------- copy(prod1) 'msgbox prod1.name End If Next End SubWhat should i be activating? The product or the part? If part, how to I select that specific one?
thanks
So, if you want to copy something from a Part, of course you need to get it...remember? ......Item("55227 Male Cavity.CATPart"). You can get it also by Instance Name...
Read a little bit more carefully the macro posted and try also to read about this in v5automation.chm file...you have a lot of things to learn when you start to do something like this.
Fernando
I understand the basics of copy from a part. This particular case required you to copy from a instance of a part within an instance of a product. I understand the product structure, but am hung up on selecting a body within two instances. Here is the section of code that needs work:
CODE --> VBScript
Sub Search(oProduct) 'THIS SUB RETURN EACH PRODUCT Dim Prod1 For i = 1 To oProduct.Products.Count Set Prod1 = oProduct.Products.Item(i) 'Rename here If Prod1.Products.Count <> 0 Then copy(prod1) 'msgbox prod1.name 'prod1.activate() End If Next End Sub '************************************************************************************************** sub copy(oProd) 'Dim productDocument1 'Set productDocument1 = CATIA.ActiveDocument set trythis = oProd.products 'Dim documents1 'Set documents1 = CATIA.Documents 'Dim partDocument1 'Set partDocument1 = documents1.Item("55227 Male Cavity.CATPart") Dim selection1 Set selection1 = productDocument1.Selection Set oDoc = CATIA.ActiveDocument Set oProd1 = oDoc.Product Set oProds1 = oProd1.Products set oProds11 = oProds1.item("Cavity Group.3") Set oMyDoc = oProds11.products set newT = oMyDoc.item(oProd.name) 'set newnewT = newT.products 'set bbodies1 = newT.Bodies set newnewT = newT.ReferenceProduct NumberOfItems = newnewT.Products.Count Dim bodies1 Dim body1 For k = 1 To NumberOfItems Set maybe = newnewT.Products.Item(k) 'msgbox maybe.name if maybe.name = "55227 Male Cavity.1" then set secndRef = maybe.referenceProduct secndRef.activate() 'error here, the following lines of code have errors as well. How do i select the particular_ 'instance? set part1 =secndRef.part Set bodies1 = part1.Bodies Set body1 = bodies1.Item("Removal : male") end if next selection1.Add body1 selection1.Copy paste end sub
