OSHA and ASME compliant belt guard question
I understand the requirements for a belt guard required for 2 sprockets and a synchronous belt per OSHA and ASME standards. The belt in question is part of skid mounted mechanical apparatus. If this skid has an enclosure (4 sides with doors and a roof) does it still require an OSHA and ASME designed belt guard? I say yes because unless you have a fail safe way to shut the machine down so there is no danger it must meet those regulations. I was told that because it has an enclosure surrounding the machine it doesn't need to meet the regulations. Anybody have experience with this type of situation?
RE: OSHA and ASME compliant belt guard question
Cheers,
gr2vessels
