Gas-Liquid transport in ducts
A two-phase fluid flowing in a pipe (6 in) which the proportions are:
W gas: 1467 kg/h ρ gas = 6,5 kg/m³ Q gas = 225,7 m³/h
W liq: 22969 kg/h ρ liq = 943 kg/m³ Q liq = 24,4 m³/h
W total: 24436 kg/h Q total: 250,05 m³/h
What is the velocity of the liquid in this tube 6 in. sch 40 (DI = 0.1541 m)?
Thank you.
Thank you.
RE: Gas-Liquid transport in ducts
Fictitious velocity in liquid phase: 0.36m/s
Supposing a homogenous mixture without any interaction, the velocity in your pipe would be 3.73m/s
But this inquiry should not get any reply. With the data given, the answer will always be V=Q/(PI()/4*DI^2) in any homogenous unity system
The velocity of the fluid in the pipe would be:
Q = V.A
v = (250.05 / 3600) / (pi * 0.1541 ² / 4)
Liquid velocity in the pipe: 3,724 m/s the same Velocity of the gas as was used the total flow and not only the flow of liquid?
Thank you.
Therefore unless the proerties relate to the specific location where you want ot know the liquid velocity (why ??) you need a proper analysis program to work it out.
The density and volumetric flow of the gas look like thay are at standard conditions (i.e. 1 bara, 15 Deg C). Without konwing the pressure at the point of interest you can't begine to estimate the velocity as you don't know if the pipe is 90%, 50% or 10% full of liquid.
Maybe if you share more data or the reason why do you need the liquid velocity we could point you toward a method or guidelines for an estimation.
