Set Value of Toggle Button?
All,
I am trying to use the value command in a menu script, however everytime I do so, I get an error:
Syntax error at line 16 in file: \\lildata01group\NX_Pilot\Configuration_Files\CPD\GROUP\TOOLING\application\MTG_MODELING.men
Found an unexpected keyword VALUE.
This is the code for Value:
VALUE statement
Specifies the initial value of a toggle button, which can be either OFF or ON. The VALUE statement is optional.
Example:
MENU UG_WCS
TOGGLE_BUTTON UG_WCS_DISPLAY
LABEL Display WCS
ACTIONS STANDARD
VALUE OFF
This is my code:
TOGGLE_BUTTON HOLE_TOOL_RENAME_SCREWS
LABEL Auto-Rename Screws
VALUE ON
Any suggestions?
-Pat
VALUE statement
Example:
MENU UG_WCS
LABEL Display WCS
ACTIONS STANDARD
VALUE OFF
This is my code:
VALUE ON
Any suggestions?
-Pat
Thank you,
-Pat
RE: Set Value of Toggle Button?
Well after a morning of messing around with the command I figured it out. I wanted to post it here so if it ever happens again it might help somebody out...
The key is you have to assign a Label and message text before you assign the Value.
Here is the code that worked:
MESSAGE Auto-Rename Screws
VALUE ON
Good luck,
-Pat
Thank you,
-Pat
