API 6 Temperature class
Hello ,
I wonder if someone can help me. API 6A says that a material is qualified for a temperature rating if the impact test is done at or below the lowerst temperature of the classification range. So in case a forged steel bar is made according to API 6A temperature class K ( -75F-180°F) does this mean that it is also temperature class U (0 - 250°F)? Shouldn´t there also be a test for the highest temperature?
Thanks in advance
Milo
Thanks in advance
Milo
RE: API 6 Temperature class
let me share what i know about API6A. im using API6A 20th edition. According to table7 page 36, impact test requirement depends on PSL and temperature range. as you mention about temperature class K(-75°F to 180°F), impact test is mandatory regardless PSL requirement. for temperature class U(0°F to 250°F), it depends on PSL that you decide based on user requirement.
Table7 also mention impact value requirement at lowest limit temperature s go-no go criteria since it was done in order to ensure steel can withstand toughness property when exposed to lowest working temperature. AFAIK, i never heard impact test was done on steel at max limit temperature (normally its for minus temp).
regards
yudhi
"The design shall consider the effects of differential thermal expansion from temperature changes and temperature
gradients which the equipment can experience in service."
Petrotrim Services
www.petrotrim.com
