Dead weight tester
Dead weight tester
Dead weight tester
Hi
We have a piping system that is buried now. These carbon steel pipes has 3inchs diameter and 3000meters length.
Can we use Dead weight tester to hydrostatic test?
These system piping must test with water at 22Bars pressure. which type of Dead weight tester we can use?
How we analyze results of the test?
Can you give me detail of the same example?
Thanks alot
