ANSI / TPI 1 - 02 Question
I am going through the TPI1 - 02 right now trying to determine the most appropriate method to analyze an existing truss and I had a question:
On Figure D4 @ Joints 1 and 5 there are two different vertical downward loads and one vertical support reaction. Where does the 82.7lb downward load come from? Why is it separated I guess is my question.
Thanks all
Thanks all
RE: ANSI / TPI 1 - 02 Question
If this is not the case, a hand copy of the figure, uploaded to this forum to look at would help with answering the question.
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
http://design.medeek.com/calculator/calculator.pl
It is still very much a work in progress. I've been concentrating most of my efforts on the basic "fink" truss since it has been a learning process along the way. The plate calculations are hopefully the next feature that I add.
