hybridshapeintersection
Hai,
I have a Geometrical Set Containing Lines and a Surface in other Geometrical Set. All the Lines in the Geometrical Set doen't Intersect with the surface which i select. I want the intersection result of all the lines which intersect with the surface excluding the Lines which doen't intersect. How to do this using Catvba......Please Help.I am in urgent need....
RE: hybridshapeintersection
Try this,,
I've not tried this but sure that this works..
If its not working then try to modify it to suit to your need, functions works though
CODE --> CATVBA
Hope this might help you.
Maddy
