How to apply loads to Truss...
Some of you may have read my previous posts pertaining to my Truss analysis questions....
I am wondering the correct way to apply loads to a truss I am analyzing? I determined the Wind loads, snow loads, and dead loads, but Ia m a bit unsure as to how to apply them? Would I go with the highest of the factored load conditions listed on ASCE 07-xx, or just analyze with actual loads sine I am not designing this for new build, but just analysis?
Thanks again all. Previous help has been much appreciated.
RE: How to apply loads to Truss...
Another question...
Since the loads ona truss are assumed to eb at the joints, I guess I must resolve the uniform DL and LL into point loads? Would you distribute the laods eavenly betweent the loints?
I am analyzing a Fink truss for the first time and I'm a little stumped on the particulars right now.
Thanks again
I would suggest you had a thorough look at an engineering book, where trusses are explained with detail, usually in first chapters.
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
This was a part of the problem with the analysis of Bow String Trusses in the 50's, contributing to their shoddy reputation.
Consequently, I almost alway load the truss as the loads actually occur, and that is not at the joints.
Mike McCann
MMC Engineering
