Catia Macro: Automating Removals
Hey,
I am trying to write a macro that will automate the removal of a tool (body) from a plate it sits in(product). It is creating the removal,
This Code is adding the affected component to "Male1", but I need it to go into "Male155227-8#K813 Male Plate"
Set product5 = products1.Item("Male1")
Set assemblyBoolean1 = assemblyFeatures1.AddAssemblyRemove(body1, product4, product5)'
assemblyBoolean1.AddAffectedComponent product5
I believe addAffectedComponent method is the issue. What should I be passing, to apply the remove to a component within the product?
Attached will be my full source and a picture illistrating what SHOULD happen.
This is one of my first CATIA scripts, any guidance is much appreciated.
NOTE: source code may be hard to follow as it contains several features that are only half implemented/ disabled.
Peter
