Changing hole type
Changing hole type
I am using NX 7.5 and I am trying to change a hole type from "threaded hole" to "screw clearance hole". When I double click on the hole feature to edit it, the other hole options are dimmed out.
Any ideas?
Any ideas?
RE: Changing hole type
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
- make external the sketch
- delete the threaded hole
- create a screw clearance hole and select the sketch
- make the sketch internal
Didier Psaltopoulos
http://www.psi-cad.com
