High-side PMOSFET failing (can't turn it off after a few days)
Hey all,
I'm having some trouble with a PMOSFET which I use to supply power to a thermal printhead. The problem is, after several days, or several power cycles, the PMOSFET seems to become a short circuit, and can't be turned off.
In the schematic provided, Q1 controls the turn-on and turn-off of the PMOSFET T1. There is a power sequencer that enables T1 after the system is ready. This seems to work fine for a while, but then the PMOSFET won't turn off, even when its gate voltage is 24V (Q1 off, R84 pulls gate voltage up to +24V).
The specs for the transistor T1: Alpha and Omega Semiconductor AOD4189: 40V, 40A, Vgs(th) ~ 3V @250uA.
http://www.aosmd.com/res/data_sheets/AOD4189.pdf
I know there is a lot of capacitance here, and I added D7 to help conduct when the power +24V is turned off, with those big capacitors fully charged. I thought maybe the body diode was failing, but adding D7 has not helped. What I have noticed, is that the resistance measured between the source and drain is very low after the "failure". I measured some new pmosfets and they seemed more normal (high resistance). Also, did a diode check on the PMOSFET body diode, and also on D7. D7 is still functional, but the Q1 body diode seems like a short.
Any thoughts on what might be happening here?
B
RE: High-side PMOSFET failing (can't turn it off after a few days)
Don't you possibly get a very large in-rush current when initially turned on because the capacitors are discharged and tied directly to ground with no current limited resistors? Could that be causing the S->G junction to fail closed? IE: The only impedance in your circuit at the moment of the great on-turning is the capacitor ESR (which you have halved by putting two in parallel) and any stray inductance from your leads/pcb traces.
B
At initial startup a worst case looks like:
Mosfet goes rapidly to Vgs(-10V) and RDS-on(0.022ohms)
Capacitor ESR could be ~0.1ohms for 2200uF aluminum electrolytic. So 0.05ohms when you put the two together.
You now have 24V across 0.072ohms = 333A, if only for an instant.
In reality the mosfet's gate capacitance will limit how quickly it reaches RDS-on, and the entire circuit should have some inductance to limit the current ramp rate. So the real amperage is probably less, but still a potentially big number.
Is this your problem? I don't know. Just pointing it out.
B
Glenn
B
B
I have been testing some of my ideas and some of the suggestions posted here before I redo the board layout. I have attached an updated schematic with my changes so far. What do you guys think? After some testing, I discovered that I probably did not need as much capacitance as I had previously. Right away this will reduce the ESR and inrush current. Additionally, I was testing some resistor/capacitor combinations to slow down the turn-on time of the transistor T1. My solution also includes a diode so that the turn-off time will be quick when it needs to be. Also, I moved some of the bulk capacitance to the source side of the mosfet. This further reduces the inrush for when T1 turns on with uncharged caps. But I did add some fast ceramic and low-ESR aluminum caps (C125 and C97). Overall, I have reduced the total capacitance used for the print load by about 50%. My tests so far look good, and I don't see any voltage dip when the printhead is printing. I saw quite a bit of voltage dip when I tried an inrush current limiter in series with the mosfet drain, so I decided to slow the turn-on time and reduce the ESR. Thanks again for your contributions. I'll welcome any additional comments.
In my test setup I'm actually using 1Mohm and 2.2uF cap to keep the turn on time very slow. I'm able to measure the inrush current, and it doesn't spike more than about 9 amps. The MOSFET can handle up to 40A (so it claims), and previously, before the adjustments, I saw such a huge spike I couldn't even measure it to its peak (over 80A for a brief few uSecs). I'll consider removing the R102. Thanks for pointing that out.
Any possibility of the gate resistor R103 at a very large value (say > 1Mohm) being so large that it won't be able to exceed some gate leakage currents and leakage from the capacitor C126? I just wonder if you keep increasing that gate resistor value that it won't be able to fully turn on the MOSFET.
B
