Internal error: attempt to access the tag of a none tagged object
I am having an issue editing a sketch. I edit the sketch in NX and then when I press finish sketch it says
Unable to redefine feature due to the following:
I have no idea how to fix it or how I caused it. I am trying to avoid deleting because I have wavelinked this sketch into almost every part in my asssignment and I am starting from scratch if I delete it. Does anyone know how to fix it?
RE: Internal error: attempt to access the tag of a none tagged object
I'd start with a part cleanup, using all the "simple" and "moderate" actions checked.
www.nxjournaling.com
Thank you for the suggestion. I tried it and I am still getting the error.
Try doing a complete update using the feature playback command.
Thank you for the Playpack suggestion. It gave me an error saying
Update Aborted
Internal error: memory access violation
General Fault Exception
Which is more information than NX gave me before. I still don't know what the problem is but I am getting closer.
You've reached the point where a call to GTAC is your next best course of action.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
