Catia to Excel File by Macro (Failure)
Hi Dear Friends,
I create a catia macro for "product" and I want to export from catia to excel. However it gives failure in Dim workbooks As workbooks Dim workbook As workbook compile failure is"User-defined type not defined" codes in below.Thank you.
Sub MatrixPrint(ByVal sName, ByVal matrix)
Dim subString As String
Dim Excel As Object
Dim Sheets As Object
Dim Sheet As Object
Dim worksheet As Excel.worksheet
Dim myworkbook As Excel.workbook
Dim myworksheet As Excel.worksheet
Set workbooks = Excel.Application.workbooks
Set myworkbook = Excel.workbooks.Add
Set myworksheet = Excel.ActiveWorkbook.Add
Set myworksheet = Excel.Sheets.Add
On Error Resume Next
Set Excel = GetObject(, "EXCEL.Application")
If Err.Number <> 0 Then
Err.Clear
Set Excel = CreateObject("EXCEL.Application")
Else
Err.Clear
MsgBox "Please note you have to close Excel", vbCritical
Exit Sub
End If
Dim a(11)
Dim i As Integer
For i = 0 To 11
If ((matrix(i) < 0.001) And (matrix(i) > -0.001)) Then
a(i) = 0#
Else
a(i) = matrix(i)
End If
Next
sTemp = sName + " = " + CStr(a(9)) + ", " + CStr(a(10)) + ", " + CStr(a(11))
'count = 0
count = count + 1
subString = Right(sName, 4)
If subString = "IF.1" Then
MsgBox sName
Excel.Cells(2, count) = sName
Excel.Cells(2, count + 1) = CStr(a(9))
Excel.Cells(2, count + 2) = CStr(a(10))
Excel.Cells(2, count + 3) = CStr(a(11))
If strsearch = sName Then
Excel.Cells(1, 1) = sName
Excel.Cells(1, 2) = CStr(a(9))
Excel.Cells(1, 3) = CStr(a(10))
Excel.Cells(1, 4) = CStr(a(11))
MsgBox sTemp
End If
End If
End Sub
RE: Catia to Excel File by Macro (Failure)
I solve this question myself.I guess I am wrong while defined excel documentation."Dim workbooks As Workbooks" is changed "Dim workbooks" then solved it.
Thank you.
In VBA, Open Tools / References and make sure you have Microsoft Excel xx Object Library selected:
xx depends on your excel version, for Excel 2010, I have 14.0
Eric N.
I understood clearly but I am working on .Catvba is it same?Because I saw your Location: c:\program Files(x86)\Microsoft Office\office14\EXCEL.EXE
first of all I am glad your help,thank both of you.It works correctly.And also I have another question if it is ok I will give a link here you are.If it is not problem can you look at this? Thanks a lot.
http://www.eng-tips.com/viewthread.cfm?qid=350505
