NX7.5 CAM - Using tool from tool library raises WCS orientation error message
I have defined a turning tool and saved to the tool library
Tool has been defined on the X-Y plane
When I call this tool into CAM the tool appears in the correct orientation and
loads onto the turret in the correct position
Adding an NC operation I get the attached error message
I have tried to redefine the tool with the insert position being topside/underside but get the same error message
Has anyone else seen this problem?
Is there a work around?
RE: NX7.5 CAM - Using tool from tool library raises WCS orientation error message
If it's not there, update the dialog with customize from.
If you still have trouble please contact GTAC - this was a common scenario when 7.5 was released.
Mark Rief
Product Manager
Siemens PLM
