Components and Cladding Loads on a Sign - ASCE 7
I am currently designing a free standing wall (which I am considering to be a sign) that will be approximately 40 feet in height. This wall will serve only an aesthetic function and will take only wind loads. The wall will be framed with steel and have an aluminum mesh facade. I would appreciate your thoughts on the following:
1. What wind loads would be appropriate to use for designing the secondary members (in this case studs or girts) that are to support the aluminum mesh? My intuition tells me components and cladding, but ASCE 7-05 makes no reference to C&C for signs.
2. If the answer to the above question is to use the C&C provisions for a building, would I only account for the external pressure coefficient and neglect the internal?
3. If the answer to question 1 is use the C&C provisions for a building, would it be ok to consider an effective area (for the aluminum mesh) equal to the entire mesh area spanning the secondary members (assuming there will be load sharing amongst this monolithic piece).
I appreciate all of your time!
Nick
Nick
RE: Components and Cladding Loads on a Sign - ASCE 7
Have fun with the Cf on Case C depending on your wall height:length ratios.
