PIle to cap connection high seismic
I have a pinned assumption of pile to cap, the auger piles extend 6" into the bottom of the cap. The piles have uplift and the longitudinal pile reinforcing is being extended into the cap to develop the bars.
Are these longitudinal bars extending into the cap required to have closed ties around them within the pile cap itself? This is a high seismic area.
RE: PIle to cap connection high seismic
There is growing evidence (again, for high seismic loading) that the piling themselves should project into the cap substantially more than the long accepted 4" to 6". Various agencies are adopting requirement for additional embedment. One that I am familiar with is the South Carolina DOT (parts of SC are at risk of significant seismic events). Here is a recent (November 2012) update to their Bridge Design Manual that requires more embedment:
http://www.scdot.org/doing/technicalPDFs/bridgeMem...
Here are the test results that the new requirement is based on:
http://www.clemson.edu/t3s/scdot/pdf/projects/SCDO...
Also, take a look at this article in the March 2012 issue of Structure Magazine, it may not apply directly to your project, but has interesting conclusions:
http://www.structuremag.org/Archives/2012-3/C-Stru...
It recommends using omega-shaped stirups to surround the portion of the pile embedded in the cap. This is to make the pile-to-pile cap joint more ductile under high seismic loading.
www.SlideRuleEra.net
www.VacuumTubeEra.net
