Acrylic Canopy / Windows Bolted Joint
I am looking for information on bolting an acrylic canopy or window to an airframe. I have seen the edges of the acrylic windows wrapped with fiberglass to provide bearing strength and elastomer bushings used. The end goal is a bushing/material combo (and process) that will provide a published bearing capability without extensive testing. Are there any published processes and analysis methods?
RE: Acrylic Canopy / Windows Bolted Joint
otherwise, using an NAS spacer would protect the plastic from clamp-up stresses.
Quando Omni Flunkus Moritati
SuperStress
Use an NAS aluminum spacer with a medium-to-hard rubber tube-sleeve around the OD of the spacer.
Spacer prevents crushing, rubber prevents direct contact between hole and metal spacer... and allows some degree of expansion/contraction.
Drilling acrylic is tricky! Special drill-bit geometry is required for decent holes.
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
Unfortunately, in science what You 'believe' is irrelevant – "Orion"
Mike Halloran
Pembroke Pines, FL, USA
