convert Kato bearing p/n 012-52200-00 to standard p/n (SKF, AFBMA etc)
We have a Kato 700KW , 875kva , 277/480vacm 60C rise, Type 19647 generator (nameplate attached)
The nameplate states the bearing is p/n 012-52200-00
Does anyone know the equivalent bearing, in terms of AFBMA number or SKF part number?
(I am looking to identify bearing fault frequencies).
(2B)+(2B)' ?
RE: convert Kato bearing p/n 012-52200-00 to standard p/n (SKF, AFBMA etc)
(2B)+(2B)' ?
(2B)+(2B)' ?
Houma Armature in Houston used to have about the best cross reference/update list for generator bearings I knew of. Might give them a try and see if they are willing to share the info for your purposes.
Regards, Mike L.
Thanks.
(2B)+(2B)' ?
