Assembly Navigator Customization
Can anyone tell me if it is possible to modify the Assembly Navigator, in NX8, to display the network parth of the files displayed? I need more, in one report, that neither the List Components program, or the Assembly Navigator will give me.
Thanks in advance,
Eric E.
Thanks in advance,
Eric E.
RE: Assembly Navigator Customization
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
My apologies for my lack of clarity.
Yes, the List Components report does display the full network path of the files in our native NX environment (i.e. G:\library\hai\unistrut\channel_nuts\uc1007t-m8). However, where the List Components report fails me is where it lists the Part Name, and the Component Name as the same value (i.e. arz14126.f01.0019 & ARZ14126.F01.0019 respectively, which is duplicated information).
What I really need is the ability to change the Component Name value to something like an object attribute value; such as DB_PART_NAME, that tells me what the component is. I know I have played with the setting under Preferences > Assemblies, and changed the Descriptive Part Name Style to a specified attribute. But, again, when I run List Components, the Part Name and Component Name columns display the same information; this time the specified attribute.
On the other side, hoping I could use the Assembly Navigator to capture the infomation I am looking for, I am able to diplay a list of components that display the Native File Name, and an object attribute name to tell me what the component is, but I am not able to display the native network path of the component. Right now, I think my only hope is to develop programming to query the assembly file and generate the report that I am looking for.
~ Eric ~
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
thread561-329148: NX - have the file name as a part attribute or string expression
thread561-317567: Easy way to get file location?
www.nxjournaling.com
