Retaining Wall Failure - Deflection or Angle
Is there guidance for a deflection (offset) or angle that when a retaining wall has reached those values, the retaining wall is considered to have failed?
Thanks in advance.
RE: Retaining Wall Failure - Deflection or Angle
I use L/240 criteria to limit deflection at the top of the stem, but that is not anywhere near a failure value.
hmmm... I imagine it would depend on what the governing code or industry standard possibly. What type of retention system is this?
FE - thanks for tip by the way.
EIT
www.HowToEngineer.com
LADOTD, use 0.4H where "H" is the exposed height of the retaining cantilever wall.
TIA30:
I assume you mean 0.04H as 4 feet seems a bit much for a ten foot wall. Just a bit.
Mike McCann
MMC Engineering
No. You apply as:
Maximum Allowable Deflection = 0.4 (Exposed Height in feet) = Results (inch)
