Proper use of round slings
Hi
There are people using round slings as in the picture below. Is that a correct way to use round slings and if
not, why? . When i look in google picture i do not see cases where it is being lifted in that way, that is
why i ask.
why i ask.
RE: Proper use of round slings
www.SlideRuleEra.net
www.VacuumTubeEra.net
If I were picking the frame you sketched, I would use nylon slings and "choke" the top horizontal member at each of the legs (after I checked the horizontal connection can support the weight). I would also add some type of corner protection pads to prevent the steel from cutting into the sling when the load is applied. It is also good to know where the center of gravity is, as you may need to adjust/slide your slings slightly towards each other to balance the load.
I would not use steel cables, this will damage the steel you are picking or the finish and they tend to get crimped at corners under loads. Steel is better suited for round objects or with shackles.
Yes, use some webbing or even weld on some lifting eyes and use a shackle with cables.
Round slings can be either steel or nylon. I was just adding there is a difference between steel and nylon and what could happen with steel.
Your added suggestion to weld a lifting eye is also a good method provided what you are lifting allows it.
Also, most competent crane companies have all the rigging necessary and if someone is not sure in proper rigging techniques, they should get them involved.
OSHA and State Safety Organizations have started requiring a competent rigger to rig the load in addition to the crane operator certifications.
The heavy highway construction company I used to work required anything other than routine lifting, to have engineered lifts, where one of the engineers in the company had to get involved.
I didn't knew that round slings chould be made out of steel? if you search on round slings on google image you only see textile round slings. The method that is being used is that they put a round sling around each beam then it is being adjusted so the round slings meet above the center of mass. I don't think they use, a spreader bar.
Also if you have a long welded structure they would need two cranes if they use a spreader bar, with the method where the slings meet above the center off mass you only need one crane.
But i wonder if this may cause damage to the round slings?
Look at the photo from SlideRuleEra, you use a spreader bar with 1 Crane.
If you have a long structure, you may not be able to use 1 crane with a spreader, it depends on the reach and crane boom height and many other factors, that is why most safety agencies are requiring experienced riggers that know all the small things to look for. If you use two cranes, you do not need a spreader bar as each crane picks directly over the load and the sling is vertical as is the case with large structural steelor concrete beams.
