Bending a solid body
I have a solid body that I'd like to bend or wrap around a cylinder in NX 7.5. I tried to use Global Shaping but the shape is projected in one direction rather than wrapped - I attached a simple part to illustrate. Is there a way to bend this solid so that the profile normal to the cylinder isn't distorted?
RE: Bending a solid body
the global shaping by curve result in nx8.5 looks better, btw. imho should be handled in global deformation
