Welding between duplex and inconel/SS316L
We would need to perform a pipe-to-pipe welding for dissimilar materials (duplex-Inconel and Duplex-SS316L), I am not a welding eng so I would like to know if someone has experiences on that and which is your advice in terms of process and filler materials.
rgds
rgds
RE: Welding between duplex and inconel/SS316L
What is the service fluid?
I let you know once I have more info.
which is the best process in that cases?
thanks
2205 to 316L: see metengr.
Best process will depend on economy as well as quality. Rrecommend GTAW and/or GMAW.
- 12.7 x 1.47 mm
- 19.05 x 1.1 mm
- 12.7 x 1.0 mm
- 28.58 x 1.47 mm
The main pipe is a plastic sheath.
thanks for your help
http://www.weldinguide.com/viewtopic.php?f=2&t...
P.No. 10H to 43
Pre-heat: 10 C (50 F)
Filler wire (GTAW): ERNiCr-3 (AWS 5.14)
Interpass temperature: 150 C (300 F) max.
Electrode (SMAW): ENiCrFe-3 (AWS 5.11)
PWHT: None
Duplex 2205 to SS316L:
P.No. 10H to 8
Filler wire (GTAW): ER309 (AWS 5.9)
Electrode (SMAW): E309-16 (AWS 5.4)
PWHT: None
Birken
Very usefull
Straight 309 and ERNiCr-3 would not be recommended. Neither filler metal would have the corrosion resistance in the environment for which the base metals were selected.
http://www.weldinguide.com/gdanastasiadis/viewtopi...
