High strength stainless steel pipe
Anybody got a recommendation for what type of stainless steel to use for 18" dia sch 40 pipe with a yield strength of at least 50 ksi? The application is a structural column that will be partially submerged in potable water.
I've got a copy of ASTM A-312 and it looks like Grade TPXM-10 and a few others will work but this brings me to my second question. Where do you buy this stuff? When we asked a few vendors we just got fish looks (mouth wide open, eyes glazed over). I need something you can actually purchase. Any ideas would be appreciated.
RE: High strength stainless steel pipe
I would contact the "Specialty Steel Industry of the United States", at 3050 K Street, N.W., Suite 400, Washington, D.C. 20007.
Voice phone 202/ 342-8630
Fax 202/ 338-5534
This organization represents many stainless steel manufacturers.
None-the-less, if you want a stainless steel material that by ASTM designation has a high yield strength, you are correct that TPXM is the material to use, yield strength of about 90 ksi. The material is sold by the trade name "nitronic". A Google search on nitronic pipe should provided you with a few vendors.
One warning to you. The piping guy might weld sections of nitronic pipe together with a standard 304L welding rod. This will cause you to have lower strength at your weld. Make sure you specify the use of matching nitronic weld rod if you need to avoid this problem.
Good luck to you.
