PIPELINE MAINTENANCE
Hi All,
The following is a job description in a pipeline maintenance work requirement. ''Prepares excavation plans in co-ordination with C & I for COMPANY Preventive Maintenance Programmes developed from IPS results.''
Please can anybody help me with explanation for the following in the above job description
1. What is the meaning of C & 1
2. What is the meaning of IPS
Thanks all
Chitessy
RE: PIPELINE MAINTENANCE
IPS could well be Intelligent Pig Survey
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Thanks All,
All responds is appreciated. All suggestions tends towards the same thing that I know. I wanted to know other people's view to be sure am not missing things up because at times different company uses different abbreviation.
Once again, Thanks
Chitessy
It would help to add a context for your abbreviations.
IPS could be 'iron pipe size' .... the old way of addressing say, a 10" pipe which is actually 10.75" OD or 10" IPS, or otherwise 10in. NB (nominal bore).
