Capacitor discharge Stud welding
I am currently trying to figure out what parameters are driving the weldability of studs on a sheet. I noticed that the thicker the sheet, the higher you have to put the voltage. Could anyone help me find a publication or an article explaining that ?
Thanx in advance.
Thanx in advance.
RE: Capacitor discharge Stud welding
The reference that I can give you for this application, assuming there is a parallel to be drawn with the sheet you have and the 3/4" flange I am talking about, is O.W. Blodgett, Design of Welded Structures, The James F. Lincoln Arc Welding Foundation, Cleveland, Ohio.
I hope that helps!
