Steel Grating Clamp requirments
Is there an OSHA requirement that states requirements for steel grating to be clamped/welded to its supports, even if it is surrounded by steel edging?
RE: Steel Grating Clamp requirments
Short answer is 'no'.
However, the grating has to be free from movement. How would you ensure that without using some kind of clip or clamp?
