AD CLICK BITWISE OPERATIONS
Hi All,
I'm new to the AD Click PLC. I'm using their software to program in ladder logic. I want to have a byte that I modify in code (using their math functions) and then output the bits as individual coils, but I can't find a way to access individual bits in a byte. Does anyone know if there's an easy way to do this or do I have to write my own subroutines using the bit datatype? I suspect this is going to be one those "DOH!!" moments.
TIA,
John
RE: AD CLICK BITWISE OPERATIONS
Automation Direct responded impressively quickly with the answer: Copy Pack and Copy Unpack do the trick.
I've heard good things about AD's tech support, and now I can attest to it.
John
