10" Backflow Device Available?
I have a sump pump pit with pumps to pump water from a bldg. off the site. I also have a 10" gravity drain from the pit to a stormwater basin. The pumps run only when the gravity pipe can't get rid of all the water coming in the pit. The problem now is that we've actually seen water flowing into the pit from the gravity pipe - the stormwater basin must be over capacity at this point. Is there a device available that I can put on the 10" gravity pipe that will allow small amounts of flow to pass under normal conditions but will prevent water from flowing backward into the pump pit?
I've seen a few backflow devices but they appear to not allow small flows to go through. they seems as though some head would be needed to open the backflow "flap" or whatever prevents the reverse flow. Any manufacture names or models would be helpful.
thanks
thanks
RE: 10" Backflow Device Available?
They usually fit between flanges, but can come as a valve body.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
