Start Command not working .Any Suggestion
I have installed Catia VR20 in my PC. The command which i have used to invoke Measure item option, i have attached below.
That particular code works in my PC whereas in doesn't work in my Office with same version installed in my office. Can someone tell me wat am i missing to make it work.
Your suggestion will be very useful
Barath :)
RE: Start Command not working .Any Suggestion
Hi Ferdo
Not working in the sense. The same script gives error, which says "Unknown Commmand". In my original script, i have preselected the points to be measured...So selection is not an issue.. Problem is with the error
Actually in my actual scenario, i have to show "n" number of point coordinate for various points and take snapshot . Hence i am trying to use macro for that purpose :)
Barath
Hi
When you want to use StartCommand is good to check manually if is available in that workbench. For this go to menu View - Commands List and run it.
Also, to understand better your problem, it will be better to post your code and the sample part (no one want to loose time to recreate your scenario - by the way, the part, as it is in your picture, will work as I described, launch the command without OK button being active).
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
from the module.1 -> right click export to .bas on your home computer
then create new catvba on office computer, import from .bas file
let us know if this work.
Eric N.
