Compressive Strength for CLSM
We are using a 250 psi mix for flowable fill, and we came back and cored a placement and tested a 90 day strength and the material had increased from the 250s to 1200-1400 psi, what could be some reasons for this massive gain in strength?
RE: Compressive Strength for CLSM
f-d
¡papá gordo ain’t no madre flaca!
I agree with fattdad, you would need to review the mix design.
Format may require adjustment...
TYPE OF CONST CEMENT MIN F'c MAX SIZE MAX AIR
TYPE AT 28 DAYS AGG SLUMP
(MPa) (in) (in) (%)
CLSM GUb 0.7 3/16 10 4-6
CLSM GUb 1 3/16 10 4-6
CLSM GUb 2 3/16 10 4-6
CLSM TRIAL MIX PROPORTIONS
MIN CEMENT 50 PCY
MIN FLY ASH (TYPE F) 150 PCY
FINE AGGREGATE 2700 PCY TO ASTM C33
MAX WATER 290 PCY
FLYASH SHALL NOT HAVE A HIGH ALKALI, SULPHATE OR REACTIVE MATERIAL CONTENT
Dik
we typically require 1/2 sack, 25 psi minimum and 100 psi maximum at 28 days for diggable. long term strength gain (90 days) is probably due to fly ash in the mix
Dik
