Thermal clamping of a ring: clamping force
I want to machine the inside of a copper ring. Therefore, I want to clamp the ring (diameter 25 mm, length 6 mm) around its outside by making aluminium clamping part. By heating the aluminium clamping part, assembling the ring in the clamp and cool down, both are fixed. My question is: how can I calculate the clamping force if the outer diameter of the ring is slightly bigger than the inside diameter of the aluminium clamp?
RE: Thermal clamping of a ring: clamping force
Try this link and example 8.28 once you have the stress values you can calculate the force
http://www.scribd.com/doc/58681195/78/THERMAL-STRE...
Your welcome
However, I found it here: http://www.faculty.fairfield.edu/wdornfeld/ME311/P...
I think you might find that both analysis will lead to the same conclusion when you apply the negative temperature gradient i.e. cooling.
desertfox
