Bending of Circular plate
Hi everyone,
Just after a bit of advice. The attached images show a circular plate(blue) mounted above a piston (green). There is a force acting over the entire top face.
Obviously the plate shown in blue is going to experience some nasty bending stresses. I'm not 100% sure how to tackle the problem by hand calculations. Should I just treat is a 2-D beam-in-bending issue? Please ignore the vertical drillings above which the blue ring is located.
Any advice much appreciated, thanks.
RE: Bending of Circular plate
First attachment
Pressue applied to the top plate surface will try to twist it out of plane, which may compromise your fastening (e.g. circular stake).
I think the case is covered in Roark somewhere.
Mike Halloran
Pembroke Pines, FL, USA
Somebody else has recommended Roark, but it appears somebody has hidden it in the library!
Even an ancient one will do.
Mike Halloran
Case 1a to Case 1d
Annular plate with uniform annular line load w at radius ro; outer edge simply supported
Case 1e to Case 1h
Annular plate with uniform annular line load w at radius ro; outer edge fixed
Case 1i to Case 1j
Annular plate with uniform annular line load w at radius ro; outer edge guided
Case 1k to Case 1l
Annular plate with uniform annular line load w at radius ro; outer edge free
Case 2a to Case 2d
Annular plate with uniformly distributed pressure q over the portion from ro to a; outer edge simply supported
Case 2e to Case 2h
Annular plate with uniformly distributed pressure q over the portion from ro to a; outer edge fixed
Case 2i to Case 2j
Annular plate with uniformly distributed pressure q over the portion from ro to a; outer edge guided
Case 2k to Case 2l
Annular plate with uniformly distributed pressure q over the portion from ro to a; outer edge free
Case 3a to Case 3d
Annular plate with a distributed pressure increasing linearly from zero at ro to q at a; outer edge simply supported
Case 3e to Case 3h
Annular plate with a distributed pressure increasing linearly from zero at ro to q at a; outer edge fixed
Case 3i to Case 3j
Annular plate with a distributed pressure increasing linearly from zero at ro to q at a; outer edge guided
Case 3k to Case 3l
Annular plate with a distributed pressure increasing linearly from zero at ro to q at a; outer edge free
Case 4a to Case 4d
Annular plate with a distributed pressure increasing parabolically from zero at ro to q at a; outer edge simply supported
Case 4e to Case 4h
Annular plate with a distributed pressure increasing parabolically from zero at ro to q at a; outer edge fixed
Case 4i to Case 4j
Annular plate with a distributed pressure increasing parabolically from zero at ro to q at a; outer edge guided
Case 4k to Case 4l
Annular plate with a distributed pressure increasing parabolically from zero at ro to q at a; outer edge free
Case 5a to Case 5d
Annular plate with a uniform line moment Mo at a radius ro; outer edge simply supported
Case 5e to Case 5h
Annular plate with a uniform line moment Mo at a radius ro; outer edge fixed
Case 6a to Case 6d
Annular plate with externally applied change in slope; outer edge simply supported
Case 6e to Case 6h
Annular plate with externally applied change in slope; outer edge fixed
Case 7c to Case 7d
Annular plate with externally applied vertical deformation at a radius ro; outer edge simply supported
Case 7g to Case 7h
Annular plate with externally applied vertical deformation at a radius ro; outer edge fixed
Case 8a to Case 8d
Annular plate with uniform temperature differential between bottom and top surface; outer edge simply supported
Case 8e to Case 8h
Annular plate with uniform temperature differential between bottom and top surface; outer edge fixed
Case 9a
Solid circular plate simply supported; uniform annular line load
Case 9b
Solid circular plate fixed; uniform annular line load
Case 10a
Solid circular plate simply supported; uniformly distributed pressure from ro to a
Case 10b
Solid circular plate fixed; uniformly distributed pressure from ro to a
Case 11a
Solid circular plate simply supported; linearly increasing pressure from ro to a
Case 11b
Solid circular plate fixed; linearly increasing pressure from ro to a
Case 12a
Solid circular plate simply supported; parabolically increasing pressure from ro to a
Case 12b
Solid circular plate fixed; parabolically increasing pressure from ro to a
Case 13a
Solid circular plate simply supported; uniform line moment at ro
Case 13b
Solid circular plate fixed; uniform line moment at ro
Case 14a
Solid circular plate simply supported; externally applied change in slope at ro
Case 14b
Solid circular plate fixed; externally applied change in slope at ro
Case 15a
Solid circular plate simply supported; uniform temperature differential between the bottom and top surface from ro to a
Case 15b
Solid circular plate fixed; uniform temperature differential between the bottom and top surface from ro to a
Case 16
Uniform load over a very small central circular area of radius ro; edge simply supported
Case 17
Uniform load over a very small central circular area of radius ro; edge fixed
TTFN
is the loading really going to be uniform over the overlapped area ? reality might be closer to a linearly increasing load, towards the (outer) edge of the overlap (the blue plate will tend to deform away from the contact face).
Quando Omni Flunkus Moritati
