My Patran does not create .dat file for dytran
I created problem about explicit nonlinear analysis, I selected analysis preference as dytran to output .dat file to run in dytran.
After I created all necessary input data, I hit the button in analysis tab, no dat file were generated. Could anyone know how to solve this problem ?
thank in advance
Charoenpon
thank in advance
Charoenpon
RE: My Patran does not create .dat file for dytran
Could please anyone know how to solve this problem ?
Thank
If I run Patran (Version 2010 64 bit) from the desktop icon, it generate the x.dat file and save it in C:/Windows/Temp folder.
If I copy the Patran icon in the current work directory (setting " %cwd " in the property menu icon), it doesn't generate any x.dat file.
I don't know if it's a problem connected to the "administrator" privileges....
Maybe someone may help me to set the right patran options.......
My laptop runs with windows 8 64 bit and I alway launch Patran with the option "Run as administrator".....
Thank in advance.
Luckily Patran is able to generate the x.dat file, even if saves it in the c:/Windows/Temp folder....
Thanks so much.
