Frequency-analog converter
I have an application that I need to measure a 0-600vdc line with a frequency range from 2khz-3khz and need an analog output of either 0-10v or 4-20ma.Any ideas where to find this
RE: Frequency-analog converter
Does the DC have a frequency?
Or do you mean that you want to measure a DC voltage with a BW of 2 to 3 kHz?
I'm afraid one needs that kind of detailed information to be able to help you further.
Gunnar Englund
www.gke.org
What you are looking for is a voltage-to-frequency converter. Many circuit designs exist with typically a 0-10V input. You will need to divide down your 600V input (probably with a resistor divider) and possibly follow the divider with a buffer before feeding the V-to-F circuit you use.
Yes, please explain more or give us a diagram. Not enough info. Comcokid may be correct, but if your frequency is impressed on a variable voltage (0-600vdc?) then a simple divider might not do the trick with a fixed input.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Skogsgurra Yes not enough information.I am looking to measure frequency on an induction melting power supply it is a variable frequency and runs at 575 vdc the frequency varies between 2khz and 3khz I would like a analog signal 0-10vdc so that I can monitor the frequency. Thanks for any help with this
Ok, it was a little bit like I thought. I think that your best option is to use a current transformer to measure the output current instead of the voltage. Then apply the current transformer output to a resistor to scale the voltage and then to a frequency to analog module like this one: http://www.laurels.com/transmitter-frequency.htm
There are several options. It will take too long to describe them all here. But what is said above is essentially the gist of it.
Gunnar Englund
www.gke.org
I agree, Gunnar. Simple and accurate.
Best to you,
Goober Dave
My impression was that the OP wanted to measure the ripple on the DC link (need to measure a 0-600vdc line with a frequency range from 2khz-3khz). But that may also be wrong. In that case, checonbill (Electrical) needs help from someone that is electrical and not (Electrical) smile
If he were in Sweden, I could certainly have done the job for him. But that is highly unlikely.
Gunnar Englund
www.gke.org
OK - I read his OP wrong. I though he wanted to measure voltage of a 600 line with a frequency output of 10V or 4-20ma.
I need to measure the frequency of a DC line that is 575 volts. The power is controlled variably with an scr fired controller. Sorry for the confusion with this application
Back to DC again? Sorry, DC doesn't have a frequency.
WHAT is the application? WHAT do you want to measure?
We can guess, yes. But as long as you keep talking about DC, nothing seems right.
Gunnar Englund
www.gke.org
What we have is a scr firing a DC voltage I need to measure the frequency that the scr is firing the DC voltage
OK. I assume that there is a firing unit? Then, there are a couple (or more) transistors driving isolation transformers that are feeding the SCR gates.
Your best option, if this is the case, is to connect a frequency counter between the cathode of one of those transistors and the 12 V (or 15 V or 24 V or whatever) ground. The frequency counter then shows the frequency with which the thyristor is fired and that, with a high degree of probabability, is what you want to know.
My patience is running out. Please do not tell us once more that you want to measure the frequency of a DC voltage.
Gunnar Englund
www.gke.org
